| | Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 | |
+49dy rasau Que Danealle MaGNum_1721 fiq allz G.i.joule mukhaz90 haizamlee osiris Azrul midi devilmeasha Kazamasaga-san farul wormzx farez kelvin45 wan_210407 abg_apis kenzs putra1691 fizerpool koie06 ayap vendetta zariq1 unknownh absolute_ahben nazjb jiwekacau paan1171 chaosworld soNa babet Kaer chocolate epol_langgar assasins superjoemanito naem 2345 tupai comel hanturaya111 geeks Ultra-Z yi_tupaijek01 Ezad man JGN8917 pais924 mantadkb 53 posters | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Wed Jan 12, 2011 10:57 pm | |
| blok resing faito aku guna skg..lubang ekzos n lubang angin/minyak memang saiz std..cma piston jer saiz bsar 57mm, std 53.8mm je kan?..so macam blok std rebore 3.++mm.. pickup mmg mcanak2.. ..apa2 blok pun tahan kalau tau limit/setting(minyak&2t)..kalau pandai setting mmg minyak lg jimat dari std.. | |
| | | paan1171 Support Crew
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Thu Jan 13, 2011 5:04 pm | |
| block dari mtor forumer greece... saiz 73 mm.. ptot la diorang bnyak pkai coolent... nk jage dari over heat... peergghh kaw2 besar beb saiz piston,.. | |
| | | koie06 Laskar Kelas I
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Fri Jan 14, 2011 9:25 am | |
| pe2 pun square engine best utk 2stroke... | |
| | | yi_tupaijek01 Leftenan Madya
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Fri Jan 14, 2011 10:26 am | |
| - koie06 wrote:
- pe2 pun square engine best utk 2stroke...
square enjin?lejang=bore ke bro koie? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Fri Jan 14, 2011 4:15 pm | |
| btol la tu bro...hehe... same @ lebih kurang...bg aku engine cm nie lg best pakai...lbey kurang cm 125z pakai piston std... cube tgk link nie ade detail engine moto2 racing 125cc... http://www.motorcycledb.com/Yamaha_TZ_125_2002/29292 http://www.maxmoto.co.uk/aprilia_rs_125.shtml | |
| | | farez Laskar Muda
Posts : 31 Join date : 27/12/2010 Age : 36 Location : Banting
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Mon Jan 24, 2011 9:34 pm | |
| ape beze blok y1 ngan y2 ek? ke same je? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Mon Jan 24, 2011 11:43 pm | |
| hoho tupai stended bore x stroke = 53.8mm x 54.7mm
nak jadi square kene rebore sampai saiz 1.00 125z
jadi bore x stroke = 54.75 x 54.7 mm <---lebih kurang square
patutla aku pki saiz 1.00 aritu best semacam jer agagagaga
tp skrg dah jatuh cinta balik ngan piston besor,syok ooo pulas pi,pulas pi | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Mon Jan 24, 2011 11:47 pm | |
| pi mana choc? skrg piston saiz brape?62mm nikasil ke? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 1:37 am | |
| pi ke jln yg lurus...mod,ada org spam nih
skrg saiz 58.5mm je,2k dah abis..nak try gak anto kat kedai kl2 bleh masuk sleeve saiz 65mm ka...perghh,mesti best kan | |
| | | midi Bintara Muda
Posts : 456 Join date : 25/10/2010 Age : 29 Location : somban
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 2:32 am | |
| aku bru dpt blok modi ni .. agak2 ok ke cara dye korek ? / port ? [img] [/img] | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 1:55 pm | |
| - midi wrote:
- aku bru dpt blok modi ni .. agak2 ok ke cara dye korek ? / port ?
[img][/img] mcm saiz dh besar je tu...lubng ejos?harga? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 3:42 pm | |
| eh kensel,65mm kl,cc up sampai 180cc je,kene kasi piston 70mm,cc jadi 210cc..dah bleh lawan budak2 greece ekekekekeke
tp mungkin pin kat big end kene kasi pki besar punya nak kasi support piston besar,rod pun kene sumbat lain jgk..alang2 tukar pin baik jack stroke trus,kasi 3mm ka..cc dah jadi 234cc
eh x cukup lg tu,kasi up skit lg stroking 5mm trus,cc jadi 249cc..wahh seroonotnyeerrrrr
ukurun baru bore x stroke = 70mm x 64.7mm = 249cc mantapppp | |
| | | Ultra-Z Support Crew
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 4:33 pm | |
| midi: kne tgk ukuran lubang ekjos/minyak dll gak bro.. ukuran yg ko tunjuk dlm gmbr tu leh tau saiz piston je.. | |
| | | man JGN8917 Laskar Kelas II
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 5:27 pm | |
- eh kensel,65mm kl,cc up sampai 180cc je,kene kasi piston 70mm,cc jadi 210cc..dah bleh lawan budak2 greece ekekekekeke
ukurun baru bore x stroke = 70mm x 64.7mm = 249cc mantapppp try wat 13mm trus choco..pnah nmpak apek cina wat spacer guna aloy kt 4 stroke... tp umah kt crank tu kena wat lain la...byk sgt modal tu..masa..hehe | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 5:33 pm | |
| alamak.. tebal mane sgt crankcase 125z.. gantung enjin rs250 kt chassis 125z la terus.. uih, spam2..~ tp dak2 greece up smpai 200cc tu tk pkai enjin 125z dh rasenye, blok apatah lg.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 7:33 pm | |
| yg kat thread my-ride ada sorang budak greece pki blok motocross,enjin 125z,crank xtau le camno rupe..cc claim 200cc..malas nak link,cari le sendirik lalala~ | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Tue Jan 25, 2011 7:42 pm | |
- yg kat thread my-ride ada sorang budak greece pki blok motocross,enjin 125z,crank xtau le camno rupe..cc claim 200cc..malas nak link,cari le sendirik lalala~
ape lagi...try la choc....mane tau kot2 berjaya capai 250cc..hehehe...ada sape2 tau formula nk kira lebar lubg ejos x? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Wed Jan 26, 2011 2:43 am | |
| 2stroke pnye cc bergantung pd saiz ruangan crankcase gak kn? sbb cmpuran petrol-udara pusing kt crank sblum masuk ke combustion chamber.. kalo crank saiz same, cme silinder blok saiz gedabak, cmpuran petrol-udara mesti rich kaw2du la ek? mainjet besau, minyak cm air.. paan: dpt gmbr blok je ke? gmbr set coolant cmne plak? ade jual yg PnP ke tupaijet? | |
| | | midi Bintara Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Wed Jan 26, 2011 3:35 am | |
| yi_ tupai jek : lubang ekzos dah korek, angin n minyak pun dh korek, ak baru bli gn mmbe ak,dh siap buat .. saiz 0.50 dye ckp..
ultra zzz~ : xde gambo lain .. blok ak hntr modi lgi kt pomen , pomen ak ckp salah korek, btul ke ni ?? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Wed Jan 26, 2011 5:13 am | |
| midi: oh, ok.. tgk lubang minyak n angin kiri kanan dh bg tajam n licin.. lubang ekzos tu point plg penting sbb biasenye lain pomen lain resipi. sng cte, nk sng kje die = die yg porting, die yg setting.. huhu.. pendapat aku la.. | |
| | | Azrul Laskar Kelas I
Posts : 146 Join date : 24/01/2011
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Wed Jan 26, 2011 12:57 pm | |
| salam..nk tanye skit..klau blok da porting,lubang ekzos pon da korek skit..piston masih 0.00 lg..head pon da potong..top pon 170-175kmh cm 2 ja..RPM plak 9K..cm ne nk bg outmeter ek ?..spoket aku pkai 15-38 ja..kna set spoket ke ?? | |
| | | chaosworld Leftenan Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Wed Jan 26, 2011 1:36 pm | |
| - Azrul wrote:
- salam..nk tanye skit..klau blok da porting,lubang ekzos pon da korek skit..piston masih 0.00 lg..head pon da potong..top pon 170-175kmh cm 2 ja..RPM plak 9K..cm ne nk bg outmeter ek ?..spoket aku pkai 15-38 ja..kna set spoket ke ??
cuba lar set spoket dlu pkai 36 ke.. tgk cam ne.. aku nye blok lebih kurang ko gak ase nye..spoket paling ngam 36-15.. 180km/h rpm 8.5k.. aku berat dlm 8x kg..haha.. leh outmeter tu mto ko.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 Wed Jan 26, 2011 3:54 pm | |
| jgn percaya sgt ngan meter tu bro...reading lain2...
moto aku lak:-
meter 170-175 > RPM 9.5k
sprocket 15-36 > berat rider 8xkg...
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V3 | |
