| 125Z + Carb RXZ V3 | |
+56lobo monster block mazakim Faiz vendetta AbeChik najmimecha -sLip- bujang komi aleb lemonish Azrul chaosworld izuan Que Danealle xopai satria_zr ayl alemm tupai comel naem 2345 wormzx midi abg_apis Kato_125 babet Mafiaflix roda karat Kaer s-rank MegatBLA3089 devilmeasha absolute_ahben KapcaiKuDie farez putra1691 Kazamasaga-san pasquale fizerpool askrun redline unknownh paan1171 hery kery nazjb chocolate laporpo_laporno Quan yi_tupaijek01 farul assasins ajizaimi capik_9981 airil Ultra-Z softoperator superjoemanito 60 posters |
| Subject: Re: 125Z + Carb RXZ V3 Sat Apr 09, 2011 10:08 pm | |
| - xopai wrote:
- bese org pki carb mili+jarum panther gamma mainjet bpe?
aku da pki mainjet 100 pn bobok lg.giler ahh.. da kong 2 plug dah.start set dari 150.letih woo.. moto standard?..sbb jarum lokel kot,pakai jarum panther kene set main jet kecik,biase atas 150,100 kecik sgt dah tue.. | |
| Subject: Re: 125Z + Carb RXZ V3 Sat Apr 09, 2011 10:50 pm | |
aku da pki mainjet 100 pn bobok lg.giler ahh.. da kong 2 plug dah.start set dari 150.letih woo.. cr jarum ori la bro..br puah ati | |
| Subject: Re: 125Z + Carb RXZ V3 Sun Apr 10, 2011 2:56 am | |
| mane carta fungsi part dlm carb tu ek? yg kalo 1/4 throttle ape yg maen, 1/2..........3/4.............full..... tk igt la jarum function ktne, pilot ktne, menjet ktne.. | |
xopai Laskar Kelas I
Posts : 133 Join date : 03/10/2010 Location : Seremban & Bangi
| Subject: Re: 125Z + Carb RXZ V3 Sun Apr 10, 2011 4:07 am | |
aku da pki mainjet 100 pn bobok lg.giler ahh.. da kong 2 plug dah.start set dari 150.letih woo.. moto standard?..sbb jarum lokel kot,pakai jarum panther kene set main jet kecik,biase atas 150,100 kecik sgt dah tue.. mybe sbb jarum lokel kot.150 bobok giler ahh.. | |
| Subject: Re: 125Z + Carb RXZ V3 Sun Apr 10, 2011 9:50 am | |
- mane carta fungsi part dlm carb tu ek?
yg kalo 1/4 throttle ape yg maen, 1/2..........3/4.............full..... tk igt la jarum function ktne, pilot ktne, menjet ktne.. kt thread lpas kot ultra...otai pon mls nk selak2 jgk ek..hahahah..aku pon mls jgk walaopon newbies...kis3 | |
pasquale Kadet
| Subject: Re: 125Z + Carb RXZ V3 Mon Apr 11, 2011 11:26 am | |
| - monster block wrote:
- haha..tgu mase je nk wat sume tu,sbb tu kne step by step...bru dpt tau performance mcmne nti..hehe.
1st step better ko sarung carb z....bertambah sdp t moto ko...cam chaos ckp... ko nak wat moto kan? erm pikap ade top pun ade t... | |
pasquale Kadet
| Subject: Re: 125Z + Carb RXZ V3 Mon Apr 11, 2011 11:30 am | |
yg kalo 1/4 throttle ape yg maen, 1/2..........3/4.............full..... tk igt la jarum function ktne, pilot ktne, menjet ktne.. the carburetor contains a pilot jet, a needle jet and a main jet with each jet working at different engine speeds, although they do overlap each others range. The pilot jet is in use when the engine is idling up until the throttle is around 1/4 open. The needle jet's range is from 1/4 throttle up to 3/4 of throttle. Above 3/4 throttle and the main jet comes into use. Check the stock specification of each jet and buy three jets that are larger and three jets that are smaller than each type. You now have six new sizes for each of the jets and can adjust the carburetor over this range. The ideal ratio of the air to fuel mixture is 12.5 to 1, this means that there is 12.5 times more air for every one part of fuel. Increasing the size of the jets requires that you also increase the amount of fuel entering the carburetor. Keeping the mixture as close as possible to this ratio will enable you to get the best tuning setup for your carburetor. | |
unknownh Bintara Kanan
| Subject: Re: 125Z + Carb RXZ V3 Mon Apr 11, 2011 12:50 pm | |
aku da pki mainjet 100 pn bobok lg.giler ahh.. da kong 2 plug dah.start set dari 150.letih woo.. jarum lokel ni kn? | |
| Subject: Re: 125Z + Carb RXZ V3 Mon Apr 11, 2011 2:48 pm | |
| - unknownh wrote:
aku da pki mainjet 100 pn bobok lg.giler ahh.. da kong 2 plug dah.start set dari 150.letih woo.. jarum lokel ni kn? aah.lokel. jarum ni elok letak kat takuk mner eh?tgh?bwh?sbb jarum ni lebih panjang.takut minyak x cukup biler full throttle.bile letak takuk bawah bru lah same panjang kedudukan eh ngan jarum rxz.tapi skg ak stil taruk takuk tgh. | |
| Subject: Re: 125Z + Carb RXZ V3 Mon Apr 11, 2011 4:41 pm | |
| jarum lokel.tu pasal bobok giler2..pakai jarum rxz je.takuk tengah | |
| Subject: Re: 125Z + Carb RXZ V3 Mon Apr 11, 2011 5:17 pm | |
| kalo xpyh pakai jarum xleh ke?xpon pakai jarum jahir baju..ngeh3 jarum mane2 pon lebih elok letk tgh2...kalo rs xckup minyak ke lbh angin ke,ejas mj n pj...kalo xda bajet,ejas jela jarum..kot2 mkin syokkkk | |
| Subject: Re: 125Z + Carb RXZ V3 Mon Apr 11, 2011 8:20 pm | |
| oh.ni sme sbb angkara jarum lokel lah nih?siot nyer jarum.xkenang budi btol. | |
lobo Laskar Muda
Posts : 11 Join date : 23/04/2011 Age : 37 Location : kuching
| Subject: Re: 125Z + Carb RXZ V3 Sat Apr 23, 2011 11:59 pm | |
| aku punye carb z, block dah rebore stended ( coz jem aritu) ekzoz ahm local. ape setting yg bagus. puck up mcm tak sedap lah. bunyi ekzoz mcm tak smooth. tapi top speed leh pegi 170.
meetoto Laskar Kanan
Posts : 258 Join date : 01/01/2011 Age : 33 Location : jb-kl
| Subject: Re: 125Z + Carb RXZ V3 Tue May 03, 2011 4:27 pm | |
| ak da pki mili nyer carb...ak da seting2...tp ssssstill semput...ssh la nk setting...mj n pj bape eh tok moto standard?? ak sa try seting byk kali,..muto lemau jer.. | |
| Subject: Re: 125Z + Carb RXZ V3 Tue May 03, 2011 6:44 pm | |
| standard gaban.. jarum = panther gamma.. mainjet = 170 n keatas.. pilotjet = 27.5.. angin bkk 1 suku - stngh.. kene ngan setting rase cam pakai carb standard,tp nk pegi top mmg rilek je.. | |
| Subject: Re: 125Z + Carb RXZ V3 Wed May 04, 2011 12:02 am | |
- standard gaban..
jarum = panther gamma.. mainjet = 170 n keatas.. pilotjet = 27.5.. angin bkk 1 suku - stngh.. kene ngan setting rase cam pakai carb standard,tp nk pegi top mmg rilek je.. superjoemanito...ni refer yg ak nyer ke or yg ats tu?? hihi | |
| Subject: Re: 125Z + Carb RXZ V3 Wed May 04, 2011 6:50 pm | |
| untuk moto standard nk pakai carb z.. | |
nazjb Bintara Muda
| Subject: Re: 125Z + Carb RXZ V3 Thu May 05, 2011 9:44 pm | |
- standard gaban..
jarum = panther gamma.. mainjet = 170 n keatas.. pilotjet = 27.5.. angin bkk 1 suku - stngh.. kene ngan setting rase cam pakai carb standard,tp nk pegi top mmg rilek je.. kalau untk head dh ptg 3mm,blok 0.50..pilotjet mmg kene 27.5 ke?mainjet kene la lebih 200 kn sbb head dh rapat ngan blok,minyak kene la lebih.btl ke? | |
lobo Laskar Muda
| Subject: Re: 125Z + Carb RXZ V3 Fri May 06, 2011 11:17 pm | |
| jarum panther gamma tu senabg cari ke bro?? ade jual satu2 ke.. klu jarum stended z pastu yg lain aku ekot bro Superjeomanito pye setting ok tak???? | |
| Subject: Re: 125Z + Carb RXZ V3 Fri May 06, 2011 11:36 pm | |
| - nazjb wrote:
- kalau untk head dh ptg 3mm,blok 0.50..pilotjet mmg kene 27.5 ke?mainjet kene la lebih 200 kn sbb head dh rapat ngan blok,minyak kene la lebih.btl ke?
aiseh 3mm ke,btl..naikkan mainjet,head dah skim paras x disarankan untuk maintain full throttle dlm jangka mase pnjg,kene pandai bace mesin,time bile nk slow,time bile nk pepah,kene pandai main throttle time nk slow n bla3x,main choke ke,yg penting kawah head kene ejas untuk safety,mnyk kene lbh sbb api plug dah makin rapat,lupe lak span n hidung blkg tue cam biase kene buang.. | |
| Subject: Re: 125Z + Carb RXZ V3 Fri May 06, 2011 11:39 pm | |
| - lobo wrote:
- jarum panther gamma tu senabg cari ke bro?? ade jual satu2 ke.. klu jarum stended z pastu yg lain aku ekot bro Superjeomanito pye setting ok tak????
ori rm30 camtue la kot,wakaka..blh je,tpi kene asah jarum tue.. | |
bdkbarunaik Laskar Kanan
Posts : 231 Join date : 28/02/2010 Location : kb, kelantan
| Subject: Re: 125Z + Carb RXZ V3 Sat May 07, 2011 3:13 pm | |
| blh spe2 tlg terangkan effect jarum asah? ak pkai asah punye setting moto jdi gile,skang nk tuka yg stendet blk,ak pkai carb catalyzer..n satu lg pe effect pkai jarum lokel? ak beli yg rm15 j,cina tu ckp yg elok dh 2 | |
komi Bintara Muda
Posts : 593 Join date : 14/09/2009 Age : 37 Location : Bukit Katil, Melaka
| Subject: Re: 125Z + Carb RXZ V3 Sat May 07, 2011 6:49 pm | |
nurkaye_akmal Pegawai Waran I
| Subject: Re: 125Z + Carb RXZ V3 Sat May 07, 2011 7:33 pm | |
| Subject: Re: 125Z + Carb RXZ V3 | |
