| Segala Persoalan V9 | |
+44softoperator mzul787 venom nazjb Shiro naem 2345 kingkong501 archonixm soNa mantadkb Or-kEi Ultra-Z eddy8075 ariffm0hd hamzi999 lencai absolute_ahben izzat_125zr babet imanhalimi lanunlaut Jokey Cabuk xapex Kaer yan_zr amirfarhan paan1171 fareez91 ramdzi unknownh tupai comel iqram man JGN8917 yi_tupaijek01 tupaiku chrome mazakim vendetta geeks ajizaimi Ezad mousepink chocolate superjoemanito 48 posters |
yan_zr Laskar Muda
Posts : 29 Join date : 10/08/2010
| Subject: Re: Segala Persoalan V9 Mon Oct 04, 2010 8:43 pm | |
| salam..nk tanya..kalau nk ribet mangkuk cluth..camne ha caranya?..dia pakai ribet camna?..getah yg nk direbet 2 org panggil apa ha?..sapa taw harga getah 2? | |
Kaer Pegawai Waran II
Posts : 1111 Join date : 24/05/2010 Location : Jay Bee - Bangi
| Subject: Re: Segala Persoalan V9 Mon Oct 04, 2010 8:58 pm | |
| rivet mangkuk klac anta g kedai jela mangkuk klac tuh.. bru rm15..
yan_zr Laskar Muda
| Subject: Re: Segala Persoalan V9 Mon Oct 04, 2010 9:10 pm | |
| boleh nk hantar kedai..tapi saja ja..mana la nk taw kot2 ada sapa2 bleh tolong terangkan.. ..boleh tumpang belajar.. | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 3:20 am | |
| rivet klac ni die bukn pkai tangan kosong je der.. kne de skill + tools + experience bru r jd.. | |
xapex Pegawai Waran II
Posts : 1040 Join date : 02/12/2009 Age : 28
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 10:03 am | |
| owww..camtu... sy dak bru blaja... bru2 men moto..harap ley ajar... | |
Jokey Cabuk Laskar Kanan
Posts : 217 Join date : 04/10/2010 Age : 84 Location : Bandaraya Pesisir Air
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 1:00 pm | |
| Assamualaikum..kwn²,tnye skit psl mtr leh?apasal bteri mtr aku slalu kong?aku baru letak bteri baru pastu x sampai seminggu trus kong..dh xde karen dh..apa masalahnye tu bro?adakah wiring?@ sebaliknye? thanks sbb sudi membantu.. rabbit | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 1:18 pm | |
| - Jokey Cabuk wrote:
- Assamualaikum..kwn²,tnye skit psl mtr leh?apasal bteri mtr aku slalu kong?aku baru letak bteri baru pastu x sampai seminggu trus kong..dh xde karen dh..apa masalahnye tu bro?adakah wiring?@ sebaliknye?
thanks sbb sudi membantu.. rabbit ssh nak ckp ape problem sbnrnya..byk bnda leh jd punca...moto lak xde depan mata... kalu air kurang mmg leh gak jd kong... kalu air bateri penuh pun leh jd kong gak kalu xcharge dlm jangka masa lama (running enjin) mengikut flow voltage & current bateri kong jd sbb xde cas2 ion yg masuk dlm air bateri tu.... dgn lebih mudah phm sbb current xmasuk ke bateri... just leh bg idea je kt sini antara problem2 yg mungkin: 1. fius dh blow 2.rectifier dh kong 3.wayar dh reput/kaput/hangus lampu dpn ko idup x..lampu dpn dpt dri supply coil magnet...lau idup maksudnya coil magnet ok lg... g kedai moto try charge bateri..rm 3 je... then tukar fius dulu... lau xsettle gak baru proceed cari punca prob tu dri part2 ln lak.. try satu2... | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 2:06 pm | |
| - yan_zr wrote:
- boleh nk hantar kedai..tapi saja ja..mana la nk taw kot2 ada sapa2 bleh tolong terangkan....boleh tumpang belajar..
kalau bush getah rosak, bila goyang antara gear&mangkuk tu ada freeplay lebih dr normal.. kalau bush tembaga rosak, ni bila dh ikat kt shaft ketat2, tp mangkuk clutch 1 set tu blh goyang2 lg.. rivet mcm paku kt mangkuk clutch tu kene grind...ada 6btg.. bila dh grind rata, gear & mangkuk clutch tu diasingkn.. dlm tu ada la getah2 bush...getah tu mmg takde jual yg original ACS...semua jenis biasa punye hrga dlm rm6-rm10.. bush tembaga utk masuk kt shaft gearbox tu pn blh kluakn...kene pandai2 ketuk atau press guna mesin...bush tu hrga dlm rm10-rm15...mmg takde yg original jugak.. biasa kalau beli getah bush tu, akan dpt skali paku/rivet baru.. dh susun getah bush tu baru blh rivet blk guna paku baru tu...ada kedai yg otai skit biasa ketuk guna tukul besi je, ada kedai guna mesin press.. rivet ni tak blh fit sgt, tak blh longgar sgt...kene sesedap rasa gak.. tak semestinya lps rivet je mst tiptop..slalunya ada gak bunyi skit...melainkn kalau beli 1 set baru, original dlm rm200++.. ni gambaran yg dh dibaraikn.. | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 2:43 pm | |
| kalu aku la kne prob ni.. aku amik multimeter "tap" kn dkt WAYAR +ve & -ve yg ikat kt bateri tu... kalu ade nilai volt kt multimeter mean suma ok la..
kalu xde nilai volt aku suspek rectifier prob... xpun wayer dri coil magnet nak ke rectifier prob... @maybe wayar dri rectifier nak ke bateri yg prob... cara ni kalu prob ni kne kt akula... | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 2:59 pm | |
| tu la..sakit pale aku pikir..bwk mtr jln jauh² pn tkt sbb meter minyak xnaik (perlu ada karen baru naik)..minyk pn main bajet je klu nk g memane..susah btol.. bro,rectifier brape harge market skrg? | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 3:10 pm | |
| jap2..ko ckp td bateri ko kong tu ko ditect mcm mana ko tau bateri tu kong?.. lampu signal malap ke..horn bunyi lemau x... kalu signal & horn suma ok & just meter minyak xnaik2 tah2 sbb wayering kt tank minyak tu prob...bkn sbb bateri..
aku pnah gak kena meter minyak xnaik...aku bukak alas getah atas tank tu & goyang2 kan sikit wayering pelampung,lepas tu suma ok..
kne state tul2 ape prob ko..kang aku salah bg info wat naya je tukar bnda yg xrosak... p/s;harga rectifier tu xtaula bro..xpnah rosak lg..tp rasanya dlm rm40 gitu2 la.. | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 5:02 pm | |
| meter aku ok klu bateri die ok..skrng nie bateri aku x ok jd meter pn x naik la..kn meter tu perlu tenaga lektik jgk klu die nk naik.. mahal jgk rupenye benda alah tu..ingtkn rm10 jer..huhuhu | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 6:12 pm | |
- meter aku ok klu bateri die ok..skrng nie bateri aku x ok jd meter pn x naik la..kn meter tu perlu tenaga lektik jgk klu die nk naik..
mahal jgk rupenye benda alah tu..ingtkn rm10 jer..huhuhu rectifier tu mcmne eh?cuba tunjukn ckt...rs mcm kt umah aku ada menda alah tu..yg original | |
yan_zr Laskar Muda
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 6:18 pm | |
he3..terbaik ah.. ..thx bro diatas pekongsian ilmu..ngah practical skang neh..tools cukup kot..tapi 2 la cam susah jek sbub x pnh buat..nanti x taw agak2 plak..takut jadi kot lain..huhu ..nk tanya pomen2 kat tempat practical ni diorg cakap bub enjin2 motor2 ni diorang kurang sket.. | |
| Subject: Re: Segala Persoalan V9 Tue Oct 05, 2010 7:49 pm | |
mahal jgk rupenye benda alah tu..ingtkn rm10 jer..huhuhu mmgla meter minyak perlukan bateri..tp tgok keaadaan gak... kalu lampu signal & horn suma ok tp HANYA meter minyak xnaik xke pelik... sbb signal & horn tu dpt supply dri bateri gak... sbb tu nak tau signal & horn ok x... sbb kalu just prob meter minyak xnaik maybe sbb pelampung/wayering pelampung | |
ajizaimi Bintara Muda
| Subject: Re: Segala Persoalan V9 Wed Oct 06, 2010 12:46 am | |
| SALAM. nk tny kpd yg pakai tupai baru ni. moto baru ni nat 2t dia dilaras plg kecik ke? xnampak benang? utk moto baru dan standard | |
lanunlaut Laskar Kelas I
Posts : 107 Join date : 14/04/2009 Age : 39 Location : Sepangar Bay, Kota Kinabalu
| Subject: Re: Segala Persoalan V9 Wed Oct 06, 2010 1:49 am | |
| salam, nk tanya 1. apa keburukan & kebaikan kalau pasang karberator aftermarket mcm uma, keihin, dsb.... 2. apa saiz yg sesuai dgn 125z blok dah porting piston saiz 1.00 ekzos ahm yg kaler hitam tu? | |
imanhalimi Bintara Kanan
Posts : 637 Join date : 16/06/2010 Age : 36 Location : Perlis->kL->???
| Subject: Re: Segala Persoalan V9 Wed Oct 06, 2010 3:04 am | |
| - ajizaimi wrote:
- SALAM. nk tny kpd yg pakai tupai baru ni. moto baru ni nat 2t dia dilaras plg kecik ke? xnampak benang? utk moto baru dan standard
haah..kasi rapat...xtaw la kot mto len ada nampak benang gak...mto aku xnampak benang nut 2 rapat.. | |
| Subject: Re: Segala Persoalan V9 Wed Oct 06, 2010 8:56 am | |
| - imanhalimi wrote:
haah..kasi rapat...xtaw la kot mto len ada nampak benang gak...mto aku xnampak benang nut 2 rapat.. oo moto aku ada nmpk benang tu keliru ckt. tp dkt plate moto tu ada la kna 2t bminyak. org lain mcmn?? | |
| Subject: Re: Segala Persoalan V9 Wed Oct 06, 2010 9:16 am | |
mahal jgk rupenye benda alah tu..ingtkn rm10 jer..huhuhu mmgla meter minyak perlukan bateri..tp tgok keaadaan gak... kalu lampu signal & horn suma ok tp HANYA meter minyak xnaik xke pelik... sbb signal & horn tu dpt supply dri bateri gak... sbb tu nak tau signal & horn ok x... sbb kalu just prob meter minyak xnaik maybe sbb pelampung/wayering pelampung oo..yg signal & horn tu ok..lampu brek pn ok..cume bteri aku tu je xcharge bile running enjin.. | |
| Subject: Re: Segala Persoalan V9 Wed Oct 06, 2010 9:33 am | |
| lanunlaut wrote: salam, nk tanya 1. apa keburukan & kebaikan kalau pasang karberator aftermarket mcm uma, keihin, dsb.... 2. apa saiz yg sesuai dgn 125z blok dah porting piston saiz 1.00 ekzos ahm yg kaler hitam tu?
paan1171 Leftenan Muda wrote: soalan no 2 x brape hambe pham lah..? saiz ape yg anda mksudkn itu..?
saiz karburator, ada yg 24mm, 28mm, 30mm....mmm mana satu yg seswai?
| Subject: Re: Segala Persoalan V9 Wed Oct 06, 2010 9:45 am | |
- oo..yg signal & horn tu ok..lampu brek pn ok..cume bteri aku tu je xcharge bile running enjin..
kalau bateri kong, biasanya signal, horn pn tak blh on jugak...termasukla meter minyak tu tak naik... lampu dpn & blkg pn mst mcm malap jer... cuba bedah jer kt kumpulan wayar yg besar ni..mst ada yg dh terputus atau dh reput... 125z aku dulu pnh kene mcm ni gak...dh pnh pn citer kt dlm ni jugak... bila dh bukak, tgk ada sambungan wayar yg dh tak cun...pandai2 la modified blk bg cun... kalau nasib baik, blh dpt wiring yg mmg byk sambungan2 lain antara 2 wayar pergi ke 2 wayar lar, 1 wayar pecah 2 lar... try la modified blk sambungan tu...buat cun2... 'bedah' kt bhgn wayar hitam yg besar tu...dr bwh bateri ke atas skit...agak2 je.. dlm tu ada byk wayar...kene 'kupas' pelan2 la takut ada wyr lain yg putus plak nnt... | |
| Subject: Re: Segala Persoalan V9 Wed Oct 06, 2010 12:22 pm | |
adeyyhh...main "bedah²" nie yg wat aku tkt nie..tkt tersalah "bedah",lain pulak jdnye..tp aku cube try la dulu klu² masalah aku nie leh setle..tp klu andai katalh wiring kt situ sume ok,kt mana lg puncenye tu? thanks bro² otai yg sudi bantu aku setle problem nie.. | |
| Subject: Re: Segala Persoalan V9 | |
