 Setting Carb & Penggunaan Pilot n MainJet V3
Go to page : Previous  1, 2, 3 ... 9 ... 16  Next
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Sun Sep 19, 2010 8:17 pm
tu la..musykil aku ni..
mto stended je..asal plug reading aku cmtu??pe sbb dia agaknye?
head aku cm plek ket..klu stended kawah dia cntik je kn..ni kawah head aku cm x smooth..x rata je..mcm kne kikis..ke sbb tu?
dh agk2 otai kne up mainjet brape ni?
dr 100 aku up 110 cm sme je..(lm gmbr)
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Sun Sep 19, 2010 8:42 pm
gambar head ngan piston bubuh ar skali klu ader...
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Sun Sep 19, 2010 8:50 pm
aish..kne bukak lak tu..
agk2 sbb pe a?
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Sun Sep 19, 2010 8:56 pm
minyak tak cukup tue psl plug kering camtu...
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Sun Sep 19, 2010 8:57 pm
pastu nk sumbat mj brape agk2?
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 8:04 pm
weh2, jwb lar pertnyaan aku kat atas tu..please... lagi satu kn, kalo blok 00, pendek kate sume standard kuar kedai lar, n then juz open box angin je, mainjet ngan pilot je kena set kan?? 2t kena set x?? sbb skang aku kasi bukak skit 2t tu
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 8:19 pm
tt
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 8:21 pm
weh besaqnye gmbr ko..kecik kn la..
ni pun aku x load abis page
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 8:26 pm
jp2..aq nk msuk gmbar plug aq..nk sruh tgk ok ke x..takut minyak x ckup..
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 8:27 pm
[img] Uploaded with ImageShack.us[/img]
cm ne?? ok ke x?? aq tgk cm kering je..tp spec mto standard kuar kilang juz open box je.. mainjet 110 pilot 17.5
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 8:28 pm
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 9:05 pm
chaosworld,stended nape nak open box?angin terlebih nnt pembakaran jd x sempurna = more carbon deposit,sama jgk kl minyak terlebih = more carbon deposit too
unknownh,aku x reti sgt pasal setting2 nih,plug first tu nampak lg kering dr plug seken..tgk kat elektrod kat tgh tu,gambar no 2 nampak hitam skit kan?
bhgian tepi plug tu nampak basah,2t cam dah ok..tp kaler besi kat tepi plug tu cam nipis jer,apakata try naik pilot satu mata..tp ni gambar amik waktu malam kan?
tjuk kt bhagian tgh mcm unknownh bt tu...br leh tgk ngn jelas...br otai2 leh komen
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 9:11 pm
ye..second amik kul 7 lebih dh.nk garib dh.first amik kul 5.
glap tu sal aku amik gmbo clah2 moto..sbb nk bg glap,,bru flash nmpk plug aku je.
kaler besi kt plug nipis??mksudnye?
da agk2 mj nk up brape ni?
up 10 cm x beze mne
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 9:16 pm
xtau le aku scratch
tgk gambar no2 tu cam dah ok skit..kasi up pilot ler 17.5 ke..
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 9:19 pm
sng kate jem la klu duk atas h.way tue,wane plug chaosworld tue nmpk cam ok,tpi tue mesti bwk biase2x je,nk btl2x tarik setiap gear 1,2,3,4 rpm max yg agk2x moto dah x blh pegi,sampai gear 4 trs matikan enjin n bkk plug nngk,jgn lupe kecikkan 2t sekali,klu lg berani try la rem kaw2x koci time moto idle,tgk cmner rpm pegi,nie kire setting advance la..
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 9:40 pm
rem2 time idle? bkn kategori advance, tp kene atas lg dr kategori expert...
dh byk kejadian2 aneh terjadi sbb rem2 time idle ni spt rod hancur, piston bersepai, +++....
dinasihatkn supaya jgn meniru aksi rem2 ni kalau tak expert.. Razz
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 9:49 pm
otai,pe mj pe sesuai aku nk bubuh ni a?
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 9:52 pm
btl..dinasihatkan jgn tiru la,klu nk tiru ok gk,tapi jgn try kt umah la,try kt luar umah Twisted Evil
aku kene bearing rod bersepai..hancuss,6 taun pki melenjen tiap2 hari x pernah wat hal,skali kene time rem kosong der perghhh sayuu...
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 10:08 pm
hu3..slamat la ak x prnh jd.smpai hari ny.anyway unknowh ko kne tgk plug reading.kami kt cni nk ckp pown x reti.cm mto ak.ak set pkai keihin.mj 180 tp sumbt 185 da bobok trus.so solution ejas lak takuk jarum.hu3..bendeny x ley ramal.kne try n error.
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 10:16 pm
carb ni aku knal mj,pj je..hehe
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 10:23 pm
solution die,hantar la set kt kdai yg brtauliah.hu3
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 10:38 pm
member aq ckp open box leh + pikap..xgitu??
PostSubject: Re: Setting Carb & Penggunaan Pilot n MainJet V3   Mon Sep 20, 2010 10:43 pm
kecik kn 2t mcm mne?? mcm standard kuar kilang?? max rpm x silap aq 9k ase nye.. otai sume, aq sebenar nye nk mto aq sedap.. ade tips x?? tu pasal aq bukak box je stakat ni.. member aq ckp leh tambh dia punye pikap..aq pun ase gak kelainan nye..
Page 2 of 16Go to page : Previous  1, 2, 3 ... 9 ... 16  Next
