 Segala Persoalan V8
Go to page : Previous  1, 2, 3, 4, 5 ... 10 ... 17  Next
fishbike
PostSubject: Re: Segala Persoalan V8   Tue Aug 10, 2010 11:26 pm
wakakaka 11k, x lar, LOL.
seribu seratus rpm lor..
oil new a week ago.
ok bro, besok I buka bagian clutch, selepas tuh baru kompom lagi.
PostSubject: Re: Segala Persoalan V8   Tue Aug 10, 2010 11:47 pm
u have to consider the rivet at the clutch basket too..maybe it already loose
WTY 4666
PostSubject: Re: Segala Persoalan V8   Wed Aug 11, 2010 10:55 pm
klu m0to stendet cne plak??
aq ad gak kdg2 alami mslh nie..cne erk?
ke kaedah aq bwk m0to salah??
PostSubject: Re: Segala Persoalan V8   Wed Aug 11, 2010 11:04 pm
mutot baru kl mungkin owner terlebih feel kot
check cluth kabel,mungkin dah longgar dan perlu diadjust balik,cek jgk kondisi rantai,mungkin dah haus..err apa kaitan rantai ngan clutch,aku sendiri pun heran
WTY 4666
PostSubject: Re: Segala Persoalan V8   Wed Aug 11, 2010 11:15 pm
kabel clutch erk?nnt la try tg0k..
rntai xk0wt..kondisi tip top lg.da tg0k da,
mgkin tlbh feel laa k0wt..hehe
KbQ4468
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 1:00 am
ermmm,,penah gak aku rasa mcm 2 kat moto aku..
slalu jadik time nak drop gear..cukup susah..
pas aku inform kat kwn aku dya kate time nak change tu kne maen2 minyak...
btol kew??
haizamlee
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 2:07 am
aku pakai bulb 12v/35w fuh....panas ow housing lampu...huhu..tp lawa..sbb kaler putih...keke
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 8:16 am
salam semut semua tupairianz...
ak nak tanya skit pade mereka yg penah tukar manifold ejos stended.
selepas tukar manifold ader tak simptom2x leaking kt lubang ejos tue..???
tention ak tgk minyak meleleh kuar mengotori bhgn luar engin tue...
ada apa2x cadangan patut ak cuba sila kemukakan, da 3kali ak
bukak pasang siap tukar gasket tp still leaking..cam harem
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 9:16 am
Tgu je lah lamp holder tu kembang yer...
Dah ramai dah orang guna lampu putih... aku sendiri mengalaminya..
Keadaan memang amat terang di kala kegelapan...
oleh kerana 35w terlalu panas bebanding 25w yang standard....lamp holder tu akan kembang kerana panas yang terlampau...
dan x semena mena kene beli lampu set baru...
Thank you....
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 9:19 am
oh man.... selalu kalau ekzos leaking selalu berkaitan ngan gasket ker... kalau dah 3 kali buke tukar gasket tu x tau nak kate ape la....
lubang ejos ko besar sgt kot..
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 11:12 am
lubang ekzos da besa sgt tu kot..manifold plak..stendet size..
mmg slalu leaking la..buat mcm ultra-z..letak gam gasket..setel
haizamlee
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 11:18 am
Thank you....
owh...tp ader x bulb putih yg 25w jew...huhu
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 12:32 pm
mentol putih ni bkn kena saman ke law pakai?
mmgla amat b'guna di kala kgelapan malam,
tp kne igt juga pmandu di hdapan,
silau mata mereka tkena dek sinran cahaya
ini mgkin akan mnyebabkn kcelakaan..hehe
alpazz
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 12:36 pm
lagi satu.. mentol putih terang dlm jarak yg dekat je..
mentol standet gk y oke.. memang clear suluh jalan..
mentol putih ni kalau kabus memang xselamat la..
xnampak jln beb.. byk kburukan je..
jumpe pak polisi pon xselamat.. ekekeke..
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 1:07 pm
baik boss akan ku lumur satu tiub silicone gasket kt area lubang ejos tue...
biar dier melekat trus ekekeke..
haizamlee
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 1:57 pm
owh..gitu ye...huhu..nnti la tukar balik...hehe...nk pakai lu...
WTY 4666
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 9:56 pm
aq rse maen myak xefek mne pn..
try tyme nk change gear tue clutch xyah kacip rpat..
slalu aq buat cm2 laa..
alpazz
PostSubject: Re: Segala Persoalan V8   Thu Aug 12, 2010 10:03 pm
kalo mase trik cluth maen2 minyak xbek utk ksihatan moto.. (betol ke?)
bagi ak xde effect pon.. (tapi still buat jgak sbb nmpk bgaye)
try maen2 cluth lak.. mesti oke punye..
fishbike
PostSubject: Re: Segala Persoalan V8   Fri Aug 13, 2010 11:47 pm
dah bongkar, rupenya mangkok clutch (yang aluminium) tuh begoyang. Skrew tumbuknya dah longgar juga. Jadi aku ganti lar rubbernya.
Bush clutch ada lar goyang sikit sahaja, tak goyang betul, tapi bush tuh tak ada jual kat sini. Jadi pake kembali lar.
Dah boleh lar, dah free sekarang bile nak shift gear.
KbQ4468
PostSubject: Re: Segala Persoalan V8   Sat Aug 14, 2010 1:06 am
owhhh...g2..tp kalo nak drop gear rase susah lak nape??
ramdzi
PostSubject: Re: Segala Persoalan V8   Sat Aug 14, 2010 5:58 pm
sspa bleh tolong bagi senarai harga x? hehe..
- Rod Original Hong Leong Yamaha
- Brake Pad depan Ferodo @ Uma Racing
- Piston Original HLY
- Bearing SKF Enduro (Enjin & Tayar)
- Carb RXZ Bosch baru
- Steelbraided wire brake Hose + bosch Dot 4 (Depan & Blkg)
- Service fork + tukar fluid dalam tu
p/s : brand apa yg ok untuk fluid dalam fork tu?
sekian!
http://www.ramdzi.com
PostSubject: Re: Segala Persoalan V8   Mon Aug 16, 2010 10:53 am
- Rod Original Hong Leong Yamaha ----> RM 230
- Service fork + tukar fluid dalam tu ----> Rm 30.... sume pakai fluid standart jer Rm 4.50 kot... tu pun dah ok.... kalau fork dah buat amik la yang mahal sikit....
PostSubject: Re: Segala Persoalan V8   Mon Aug 16, 2010 11:21 am
- Brake Pad depan Ferodo @ Uma Racing RM15-Rm30 (uma racing utk 125z baru dh takde lg)
- Piston Original HLY RM315, Ring RM95
- Bearing SKF Enduro (Enjin & Tayar) RM20-RM40
- Carb RXZ Bosch baru original RM250++ (tu pn kalau ada jual lg)
minyak fork aku recommend pakai minyak gearbox kete (MTF)..baru mantap...
tp kalau utk bdk2 skola, pakai jerla minyak fork brand ape2 pn..ok jer...
PostSubject: Re: Segala Persoalan V8   Mon Aug 16, 2010 11:28 am
nk nanges tgk rege piston ori...rege ring ori
saje ley bli piston+ring+rebore skali...
PostSubject: Re: Segala Persoalan V8   Mon Aug 16, 2010 11:44 am
BEARING SKF sama harga ngan NACHI ?????
Segala Persoalan V8
Page 4 of 17Go to page : Previous  1, 2, 3, 4, 5 ... 10 ... 17  Next
