 Turun Fork Depan Kebaikan Atau Keburukan
fishbike
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Sun Sep 12, 2010 12:09 am
qqqq, awak nak modi betul2 supaya keras, ngan sebisa mungkin tak merusak durability fork? n juga x merubah posisi fork?
ok, do you ever see front shock absorber that Honda CB100 have?
There's a nipple for air compression at the upper cap.
I love that stuff.
When you had modified it well to your 125z, hehe the trick is not using air from compressor. Because air is easily pressed.
Use Nitrogen, like for car-wheel. Expensive, but that stuff rocks, it 'levitates' as a good rebound, rather than usual air.
Air can cause more quicker heat, rather than Nitrogen. So, logically it will reduced the potential of steel-friction, and keep the oil shock as cool as possible. So the oil will stay in its durability and performance.
If you don't use the nipple, it's hard to inject the stuff into inside the fork.
Well, the Nitrogen is small in capacity, so won't give any meaningful side-effect.
So hard or soft rebound, you just increase or decrease the gas value through the nipple.
enzoanz
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Sat Sep 18, 2010 10:34 pm
dh lower fork ptg td.. rm20 je.. klu diy mayb xckup brg kot.. coz kene oter sket kt pemegang fork 2(ape ntah name die).. lower dlm 1inci(tyr dpn saiz 70/90)..
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Sun Sep 19, 2010 12:08 am
Quote :
rm20 je?tengkuk ada potong x?
murah ah tu....kt kdai mne wt?
enzoanz
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Tue Sep 21, 2010 4:58 pm
amirfarhan wrote:
Quote :
yup. murah yg ak pnh jmp.. servis pn bagus je tauke 2.. tengkuk xde potong cume tundukkan sket je.. ko nk bt ke..? dtg tepeng nnt ak bwk ko g pomen 2.. ok?
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Tue Sep 21, 2010 8:03 pm
hehehe..effect dia bila ride malam2..xnmpak jln siot..
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Tue Sep 21, 2010 10:42 pm
aiseh..bkn ke blh adjust level lampu dpn tue bro,bg dongak skit la..
enzoanz
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Wed Sep 22, 2010 12:20 pm
betul 2.. hehe.. klu xnmpk lg 2 dh rabun nmnye..
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Wed Sep 22, 2010 12:38 pm
sy punya lampu da hbs dongak da..lampu hi, mcm lampu low je..lampu low suluh dpn mudguard..igt nak pasang spotlight la pas ni..hehehe..
mgkin bole modi sikit kt leveler lampu 2..cma xde msa nak buat..lalala~~~
enzoanz
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Wed Sep 22, 2010 12:42 pm
owh.. yeke.. bnyk x turun fork n potong tengkuk 2..? klu kes cani kne kreatif sket cane ko nk modi lmpu 2.. huhu
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Wed Sep 22, 2010 1:34 pm
Quote :
oh..taiping ke..ak kt kb..jauh gak tu.....kt cni pomen kte ssh la...rumit la..ape la...
charge plak mesty lebh...ssh ckit
smart ckit turn fork n kasi potong ckit...
ko trunkn fork brape mm?
enzoanz
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Wed Sep 22, 2010 1:46 pm
amirfarhan wrote:
Quote :
mmg jauh.. mmg pomen 2 ckp 125z ni rumit sket.. turun fork ex5=rm10, lc=rm18, 125z=rm20(rate hrga die).. tp servis die mmg ok la.. puas ht ak tgk die bt.. hrga pun murah.. berbaloi2..
nismoskyz
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Sun Sep 26, 2010 7:18 pm
bro2 skalian..klo trunkn fork..cover set yg cover fork uh kna potong x?
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Sun Sep 26, 2010 7:22 pm
klu x nk potong trnkan ngam2x sampai cover tue je la,klu lebih mmg kene potong ar..
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Sun Sep 26, 2010 8:03 pm
lowered stgh inci je max kot kalo tnk potong cover fork tu..
pergh, mcm tkde..
potong je..
kasi lowered 1.5-2inch..
aku nye coverset orimoto pn aku potong je..
haha..
kalo syg nk potong ori, beli yg local spasang..(naseb la kalo kaler cover fork ngan mudguard dpn 'lari' sket.. haha)
ngee~~
gudluck!!
nismoskyz
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Sun Sep 26, 2010 8:29 pm
owh..thx broo..bkn pe..br je pas trun fork td..die charge rm25..trun 1 inci..tyr TT900 80/90..
agk smart.. Very Happy
Fendi Faito
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Mon Sep 27, 2010 2:32 pm
cantik standard dapat wekang.
http://125z.darkbb.com
redline
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Mon Sep 27, 2010 4:47 pm
dah bertahun aku turun fork, stakat ni x penah ade prob lg...lebih kurang 1 inci lebih...still bleh up/wekang...moto pun smart je...
gilgamesh88
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Mon Sep 27, 2010 9:04 pm
pergh, mcm tkde..
potong je..
haha..
ngee~~
gudluck!!
Ho2,ak pn sme..2 inci ak trun..kaver ori kasi tebuk..
azizi5587
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Tue Oct 12, 2010 1:06 pm
asury wrote:
cmfirm ujung bln nih aku antar kedai kasi turun...
pomen aku kata xbleh turun, sgkut...
aku g kedai lain plak....
padan muka dia...
hahahahaaha...
ko mmg lawak....
apishoul276
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Mon Nov 01, 2010 2:45 am
aku turun sehabis rendah, potong besi honk, aku pakai 60/90,
tayar belah atas da tak nampak, nampak rim ea, hahah
gilgamesh88
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Wed Nov 03, 2010 10:55 pm
hery kery
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Mon Nov 08, 2010 11:27 pm
enzoanz wrote:
amirfarhan wrote:
Quote :
murah2..aku slalu gk trun tpeng....rnda sna..dai mne 2..kt pekan ker??
bender
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Sun Nov 28, 2010 4:22 pm
dulu2 masa zaman2 baru nak 'up' mmg best la...naek sorang plak tu... nak amek corner pon sodap... titik graviti pon rendah... lebih aerodinamik... moto ak da turun kan fork + potong tengkuk 5 taun lepas sampai la skarang... mmg x de masalah.. tapi sejak da ade bini ni sakit der nak bawak... tangan krem, lenguh pinggang.. kesimpulan nye.. klu naek sorang mmg sedap...
Chimunk
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Mon Dec 13, 2010 12:57 pm
Salam semua,,
saya org baru dlm forum ni ingin meminta pndpt anda smua,,,apa masaalah mto aku apabila stat nak jalan tu kepala moto goyang semacam je tp bila dah laju dlm 80 dah x ada goyang dah....blh bg pendapat x?Plase....
PostSubject: Re: Turun Fork Depan Kebaikan Atau Keburukan   Mon Dec 13, 2010 4:22 pm
Chimunk wrote:
Salam semua,,
wasalam,moto baru ke 2nd bro?,ape2x blh perkenalkan diri dulu,pegi kt link ni..
http://125z.darkbb.com/pengenalan-diri-f3/attention-to-all-new-members-t2-500.htm
http://125z.darkbb.com/pengenalan-diri-f3/my-email-ym-friendster-handphone-location-t42-100.htm
Page 5 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
